Forums >> Revit Building >> Technical Support >> family "profile" / "profile hosted"
Mon, Apr 22, 2013 at 3:35:36 AM | family "profile" / "profile hosted"
petersmith
Hi,
I see there is a template for the family "profile" and profile hosted" ? What is the difference between these two family's? And when do I to use the family "profile" and "profile hosted'?
Mon, Apr 22, 2013 at 7:33:54 AM | family "profile" / "profile hosted"
Hosted - seems pretty obvious.... it is hosted by something - like a wall - a roof edge.
Fri, Jan 12, 2018 at 7:42:31 PM | family "profile" / "profile hosted"
jbell
Thanks for the wise curse answer. How about a little detail.
Sat, Jan 13, 2018 at 7:08:01 AM | family "profile" / "profile hosted"
Not a wise crack answer... You obviously need to do a little research and learning on your own.  Did you ever think about using your help and serching it for profile?   If so, you would have found this as a beginning.  Also if you look in your library, you will find various profiles and examining them will help you to understand what they are used for.  Profiles are used for creating solid and void forms as an extrusion along a path.
You do understand why a door is a hosted family (typically)?
Thu, May 24, 2018 at 6:58:43 AM | family "profile" / "profile hosted"
Marcodelu
Wow... I would say... very friendly moderator! Puh
C-Channel Profile sweep issues?
Fri, Apr 29, 2011 at 11:47:24 AM
changing the "family" and "type" names
Mon, Apr 2, 2007 at 5:33:49 PM
tagging by "family name" and "family type"
Mon, Jun 1, 2009 at 8:54:54 PM
Hide Mullion Profile When the Visibility Setting is Fine
Mon, Mar 13, 2017 at 10:32:48 AM
Gable wall without using "Edit Profile"?
Tue, May 18, 2010 at 7:45:10 AM
Page generation time: 1.5651
