Forums >> Revit Building >> Technical Support >> Export 3d DWG issues
Wed, Feb 1, 2006 at 11:31:36 PM | Export 3d DWG issues
BLIESNER
I am experiencing issues when i export to dwg to import into viz/ max. i am running a p4 3.2 with 2gig, and it seems to take at least twelve hours to export to dwg. now when i open the same file with my old p3 2.0 with 512 i can export the same file to 3d dwg in about 5 minutes. does anyone know if there is a setting that enables this process to be sped up because i have no idea why a slower pc does the export in under 1/100th of the time.
Thu, Feb 2, 2006 at 2:34:56 AM | RE: Export 3d DWG issues
eldados
eldados Avatar
4.5 Stars: 8 Votes
are you on a network? if you are on the network, do you have your material (accurender) stored somewhere else?
Integrator
KarelCAD
Thu, Feb 2, 2006 at 5:29:45 PM | RE: Export 3d DWG issues
BLIESNER
i am on a network however, but both computers are looking to the same accurender dir to pull the required information. i have also tried to copy both revit file to my local c: and export to my local c:. i have performed this on both pc's with the same outcome. any ideas????
Fri, Jun 28, 2013 at 8:27:02 AM | Export 3d DWG issues
dande
Have you tried linking you file in max or export to FBX and import the fbx
DWG export issues
Wed, Aug 8, 2007 at 7:10:48 PM
Revit Export to 3D .DWG still will not export Ceiling Grid Hatches?
Wed, Feb 11, 2009 at 4:42:25 PM
EXPORT TO DWG - Problems
Wed, Feb 22, 2012 at 2:28:53 PM
REVIT LT 2022 issues with exporting to dwg
Tue, Sep 21, 2021 at 1:08:13 AM
Export Linework colors to DWG
Wed, Sep 14, 2016 at 12:04:12 AM
Page generation time: 0.7132
