21 Users Online (19 Members):
Forums >> General Discussion >> Revit Project Management >> How to not have elevation line crossing the model? (level heads on both sides)
28 Posts No Rating |
I like having elevation marks on both sides of an elevation drawing. However, I don't want the elevation line crossing the model. Is there a way to have the elevation line extend only to the edge of the building? Please let me know if my question is confusing. I'm new to Revit. I might not be describing what I want properly.
Thank you.
Please explain - an image would help.
You cannot have for example First Floor El.100'-0" to show on both sides of the building without the line showing through the entire building. If you want the line to stop at the building edge you need to pick one side or the other to have the Elevation marker show on.
Thank you, teafoe5. I am very surprised. I thought it should be simple enough, but I just couldn't find a way. Is it really impossible to have level heads on both sides of an elevation without the line crossing the entire model? The section marker on plan can do that, why not level line?
0 Posts No Rating |
Hi,
Probably a bit late for you, but you could simply change the colour of the Level Head property to "white",
you may need to adjust the RGB values of the colour "White" to something like 252,252,252 instead of 255,255,255
depending on your printer setting for the lines not to print.
Hope this helps.
Which is better? (For repeating same elevation level heights) |
Fri, Jan 11, 2008 at 10:00:30 AM
Break the Level Line |
Mon, Dec 5, 2011 at 4:39:08 PM
Elevation Markers, Level Heads, Section Markers, all at Varing Scales |
Mon, Feb 20, 2012 at 11:33:58 AM
level heads |
Thu, Sep 7, 2006 at 5:34:27 PM
Level heads - Geodetic vs. datum |
Tue, May 17, 2005 at 7:44:43 PM
