Forums >> Revit Building >> Technical Support >> "print"-commando
Fri, Apr 19, 2013 at 4:50:02 AM | "print"-commando
petersmith
Hello,
I would to place the commando "print" in the quick access toolbar, because I use this very much. Each time I have to press the revit-logo and then the commando "print". It's not convenient. I must be easier and more user-frindly.
And the question is:How can I to place the "print"-commando in the quick access toolbar?
Fri, Apr 19, 2013 at 7:22:44 AM | "print"-commando
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
There isn't a way to do that.  But you can just press Ctrl P and that will take you right there.. prolly quicker than your mouse.
Fri, Apr 19, 2013 at 7:50:50 AM | "print"-commando
petersmith
I'll be afraid of this answer. Whole the day looking for the buttom or commando how I can solve this user-unfriendly problem. I hope Autodesk will improve this in revit 2014 next time.  unlike! unlike!
typically a point of improvement for in the wishlist Smile
Fri, Apr 19, 2013 at 10:24:55 AM | "print"-commando
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
I do have to agree. ctrl+p works but I've always wondered why REVIT is the only software on the planet that does NOT have a print shortcut button.
Believe it or not it used to be there until they went to the ribbon. Then it dissappeared ? Did someone just forget to put it in ? There's no logical reason to NOT have it there.
Edited on: Fri, Apr 19, 2013 at 10:36:07 AM
Print Error "Display Error"
Tue, Dec 20, 2005 at 5:04:34 PM
Plan Render-No "View Size"?
Tue, Jan 13, 2009 at 4:25:21 PM
"do not print" settings?
Mon, Sep 8, 2008 at 1:21:31 PM
Trouble printing to Oce 30"x42"
Thu, Sep 11, 2008 at 3:51:19 PM
Problems plotting "shading with edges"..................
Mon, Mar 24, 2008 at 8:01:09 AM
Page generation time: 1.0493
