Forums >> Revit Building >> Technical Support >> Railing: Do they or Do they Not Display in RCP?
Thu, Apr 18, 2013 at 7:41:14 PM | Railing: Do they or Do they Not Display in RCP?
crwinchester
crwinchester Avatar
3.5 Stars: 6 Votes
I've searched through a few of these threads and did not find an answer to the above query. Most users say it is a matter of adjusting the view depth. This does not seem the case. I have a soffit edge that I've modeled as a rail for scheduling purposed. The height of this object is slightly above 10'-0". The view range for the RCP has the cut plane set to 7'-6" with the top and bottom depoth set to unlimited. The visibility graphics have railings checked as visible. Any ideas? Or dare I say, is this a defect? Thanks in advance.
Fri, Apr 19, 2013 at 7:01:16 AM | Railing: Do they or Do they Not Display in RCP?
I don't see how railings will show.  They don't typically cut in plan views.
Fri, Apr 26, 2013 at 1:34:45 PM | Railing: Do they or Do they Not Display in RCP?
crwinchester
crwinchester Avatar
3.5 Stars: 6 Votes
Thanks for your reply. I suppose that makes sense, but it is definitely unfortunate. Detail lines it is.
Railing System Family Visibility in RCP
Wed, Feb 4, 2009 at 2:48:22 PM
Railing material won't show up
Wed, Jan 13, 2010 at 12:20:34 PM
ceiling plan - exposed structure
Mon, Sep 29, 2008 at 11:28:23 PM
Window sills and head
Thu, Apr 7, 2005 at 2:41:05 AM
2D light family shows too big on RCP legend
Wed, Jul 3, 2013 at 11:35:44 AM
Page generation time: 0.1248
