13 Users Online (11 Members):
Forums >> Community >> Newbies >> Wall sweeps around door?
18 Posts No Rating |
Hello! I'm new to utilizing wall sweeps. And model-in-place components. I'm wondering what the best approach might be the build this door and arch (see attached photo)? Thanks in advance.
No image attached
Pay attention to your file size. jpg's - gifs are best.
Ohhh...it was a 3MB file...See attached. Thank you!
For the arch, you could make a special family based on the same principles used in an arch top window here in the downloads. But I would probably do a model in-place element slightly proud of the brick face as an arrayed element.
The inside area is a seperate wall with door. Sketch edut the wall to cut the hole in the brick wall.
Problem connecting wall sweeps (horizontal and vertical) |
Fri, May 4, 2012 at 2:07:26 PM
Angling Wall Sweeps |
Mon, Aug 15, 2011 at 1:26:41 PM
Wall Base/ Wall Sweeps and Door "Clipping/Cutting" RVT 2014 |
Fri, Jul 8, 2016 at 12:35:14 PM
Wall sweeps cover door trim |
Wed, May 23, 2007 at 5:39:11 PM
Wall sweeps VS Generic Models |
Sat, May 21, 2011 at 10:14:19 PM
