Forums >> Community >> Newbies >> Adjustable Column Issue
Wed, Feb 1, 2006 at 6:14:00 PM | Adjustable Column Issue
arccodex1
3 Stars: 1 Votes
When I try to adjust the Capital Offset on the attached column I get a line halfway down the column shaft. I used the fillet line to get rid of it initially, but it reappears when you adjust the Capital Offset. Any suggestions? It's critical that I resolve this because we have a number of simliar columns to build. Post edited on 2006-02-01 18:14:15
Wed, Feb 1, 2006 at 6:20:57 PM | RE: Adjustable Column Issue
arccodex1
3 Stars: 1 Votes
Figured it out. I just had to dimension from top of capital to the point of directional change. It was the changing angle of the top half of the column that was causing the problem. Ok posted that in the wrong Forum too. Post edited on 2006-02-01 18:54:06
Plan adjustable door swing issue
Mon, Oct 1, 2012 at 9:13:26 PM
Column Join issue
Wed, Oct 11, 2017 at 10:10:15 PM
Family With Multiple adjustable elements
Tue, Sep 27, 2011 at 8:41:08 AM
Adjustable Angle Reference Gets Lost once a 90 Degree Angle is Formed...
Wed, Sep 30, 2015 at 12:28:52 PM
column base constraints
Mon, Feb 10, 2014 at 8:02:30 AM
Page generation time: 0.2642
