Forums >> Revit Systems >> Tips & Tricks >> Revit "Show Disconnects"
Wed, Apr 17, 2013 at 9:42:15 AM | Revit "Show Disconnects"
OneAlex
OneAlex Avatar
Afternoon All,
Ive tested my model using the show disconnects tool. Most components have linked successfully. Even when i drag the two items together by the end drag/snap points they still are not connecting. Is there a tool im missing to connect items more accurately?
Image attached of an example between a pump and pipe,
Alex
Thu, Apr 18, 2013 at 1:41:35 PM | Revit "Show Disconnects"
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Check the connector types in the families. Connectors can have 'direction' ----> Maybe that's the problem ? As in in bound, out bound.
{3D} view set to "Shading with Edges" looks like "Wireframe" with color...
Wed, Aug 12, 2009 at 7:05:45 AM
11
changing the "family" and "type" names
Mon, Apr 2, 2007 at 5:33:49 PM
Existing 12" wall w/4" brick-4" cavity-4" brick. Can't get plan brick to s
Wed, Apr 8, 2009 at 5:08:39 PM
Reference a "grand total" from a schedule??
Wed, Oct 7, 2015 at 12:45:57 PM
callouts with "typ" label?
Mon, Sep 15, 2008 at 1:44:41 PM
Page generation time: 1.7562
