Forums >> Revit Structure >> Technical Support >> Given a central model: unable to select some elements
Tue, Apr 16, 2013 at 10:28:10 AM | Given a central model: unable to select some elements
crosado
Revit Structure 2013
When I opened the model I detached it from central, I also detached and discarded worksets. I am still unable to select the grids in plan view and some model elements in 3d view...
secondary problem: in the same model, I can't see the section cuts symbol that i make in plan. even when i copy an existing section cut symbol it disappears once i place it.
shed your revit wisdom on me, thanks
Tue, Apr 16, 2013 at 11:11:12 AM | Given a central model: unable to select some elements
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
if you cant select an object check and see if there are any design options.
for the section cuts it just sounds like they are turned on in visiblity and graphics
Tue, Apr 16, 2013 at 12:19:12 PM | Given a central model: unable to select some elements
View scale may also be too small to show sections.  Change to a large scale and see if they show.  If so, you can change the "show in scales larger than" settings.
Tue, Apr 16, 2013 at 12:55:06 PM | Given a central model: unable to select some elements
crosado
You guys are awesome.
I found Design Options and was able to edit things that were "locked". I have never used Design Options so hopefully I can become more familiar with them.
There was a filter for "hiddedn unsheet views" that makes it so that no new cuts/elevations/detail symbols will appear unless i have placed them on a sheet. Again, something I am unfamiliar with but may be learning about with this project.
Thanks again.
I can not select some elements in a file
Wed, Apr 10, 2013 at 5:28:15 PM
Ownership of Elements in Central Model
Tue, May 19, 2015 at 1:03:36 PM
Unable to select grid lines after pinning them
Fri, Dec 13, 2013 at 5:42:49 AM
Working over WAN central model
Sun, Aug 26, 2012 at 9:59:26 PM
was given a central model, am unable to view any new section cuts
Wed, Mar 13, 2013 at 4:16:24 PM
Page generation time: 2.2874
