Forums >> Revit Systems >> Technical Support >> Link excel to revit
Tue, Apr 16, 2013 at 7:45:02 AM | Link excel to revit
adgreen
I Linked an excel file to Autocad..and it appear in xref dailog...
once I linked it to revit... nothing happen..
may be an action should take a place in Autocad... need help..
thanks for all...
Tue, Apr 16, 2013 at 8:01:42 AM | Link excel to revit
Nothing wrong here.  Contrary to the response you got on the other thread you can't do this.
Tue, Apr 16, 2013 at 8:40:54 AM | Link excel to revit
http://www.dotsoft.com/revit/xl2revit.htm
An add on to do what you want ... $
Tue, Apr 16, 2013 at 10:07:52 PM | Link excel to revit
RevitBJO
BIMLink is another add-on that I have looked at..for what it's worth.
It's annoying that Revit doesn't have an in-built link for excel. Does anyone know if this is being looked at by AUTODESK ?
I try to avoid this workflow, though sometimes it's required when your back is against the wall. How did you insert your excel table into AutoCAD ? The way I got it to work was to use the 'Table' command then insert the data from the excel sheet using the 'From a data link' insert option. You can specifiy the range of cells you want to capture in your spreadsheet using this method and then you can insert into your Revit project.
IMPORTING EXCEL
Fri, Sep 7, 2012 at 8:26:43 PM
EXCEL LINKING REVIT MEP 2012
Wed, Dec 28, 2011 at 3:06:20 PM
Revit to Excel massing and cost estimation
Mon, Nov 2, 2009 at 10:36:14 AM
EXCEL LINKING!
Mon, May 8, 2006 at 8:19:56 AM
Linking Revit files to Excel
Wed, Jan 22, 2014 at 3:30:36 PM
12
Page generation time: 1.3546
