Forums >> Revit Building >> Technical Support >> Creating levels below topography/raising topography?
Fri, Apr 12, 2013 at 10:59:44 AM | Creating levels below topography/raising topography?
tobsterT
Hey!
This might already have been brought up and I've just missed it..
Anyone knows a way of creating levels below a topography or even raising the topography to a higher level?
I'm trying to build a parking garage under ground (which has proven to be a b*tch).
Any help would be greatly appreciated! Smile
Fri, Apr 12, 2013 at 1:22:50 PM | Creating levels below topography/raising topography?
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
If I was modelling a parking structure below a toposurface I would create a great thin 'Pad' based on the footprint of the building and drop it down below the lowest point of the structure.
Essentially creating an excavation. Same as with a basement.
Pads placed below a toposurface 'remove' material. Pads placed above a toposurface 'add' material.
Edited on: Fri, Apr 12, 2013 at 1:23:44 PM
TOPOGRAPHY SPLIT PROBLEM
Mon, Sep 22, 2008 at 2:51:42 PM
Topography dissapearing
Wed, Nov 7, 2012 at 2:46:15 PM
matching contour lines from civil CAD when creating Topography (2019)
Fri, Dec 4, 2020 at 2:09:46 PM
Creating a topography from 3D CAD survey import
Thu, Feb 23, 2012 at 7:53:01 AM
Giving topography thickness when rendering
Thu, Jan 22, 2009 at 9:42:06 AM
Page generation time: 0.8058
