Forums >> Revit Building >> Technical Support >> Overlapping Property Line Corners?
Sat, May 29, 2004 at 10:41:14 AM | Overlapping Property Line Corners?
PJasonL
Is there a setting available to allow overlapping for property line corners? J
Sat, May 29, 2004 at 1:32:20 PM | RE: Overlapping Property Line Corners?
skisouth
5 Stars: 3 Votes
The property line has "intelligence" behind it, so I don't think there is an option to extend these lines as area and volume is based off of them. However, you can create a matching line type and simply "create" the extension that looks like the property line.
Property line
Tue, Oct 13, 2009 at 5:31:57 PM
ROUNDING VALUE ON PROPERTY LINE BEARING
Fri, Apr 8, 2016 at 1:13:37 PM
How to draw this property line?
Sat, Jan 23, 2016 at 4:48:18 PM
Property line tables on sheet
Tue, Mar 14, 2017 at 1:29:57 PM
Property Boundary lines
Tue, May 30, 2006 at 10:45:31 PM
Page generation time: 2.7408
