Forums >> Revit Building >> Tips & Tricks >> Easy trick to creating a schedule with wall heights
Fri, Apr 12, 2013 at 9:48:29 AM | Easy trick to creating a schedule with wall heights
rayray979
Rather than using the very inaccurate Area/length formula (when there are any doors or windows) simply click the wall chainging it to a part.  Select the wall giving it a distinct type mark so you can filter it in the schedule.  Then create a parts list that has the height parameter.  When finished in your properties box change the parts visibility from "show parts" to "show original" turning them back into walls, now when you move the wall the schedule automatically updates as well.
This was done in 2013 but I am sure the previous versions are similar (:
Edited on: Fri, Apr 12, 2013 at 9:50:11 AM
Schedule Wall Heights
Wed, Apr 14, 2010 at 10:45:25 AM
Ceiling heights in schedules
Thu, May 26, 2005 at 9:26:42 PM
Wall heights - change all heights simultaneously
Wed, Sep 7, 2011 at 7:43:24 AM
Why do all my Wall Heights default to 20'-0" !!
Wed, Apr 26, 2006 at 4:31:21 PM
Wall Square footage
Wed, Aug 27, 2008 at 3:57:20 PM
Page generation time: 2.1130
