Forums >> Revit Structure >> Technical Support >> 3D view detail
Thu, Apr 11, 2013 at 11:41:35 AM | 3D view detail
crosado
i have a floor that is basically concrete on metal deck. when i view it in elevation/section i see the corrugation of the deck. when i view it in 3d the floor is a just a slab with no detail of the metal deck. i have changed the detail to fine and messed with the discipline setting and the visual style but none of these adjustments are affecting how the floor appears. what am i doing wrong?
(i noticed something similar the other day when i copied a wall from one project to another project; in the original the detail in the 3d view was fine, but in the new project there was no detail just a generic wall)
Thu, Apr 11, 2013 at 11:54:46 AM | 3D view detail
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Your issues are not related. Steel deck does not show up in 3D. Period, end of story.
Your second problem may be related to opposing 'materials' from one project to the next.
If you copy and paste a wall from one project to the next it will not convert the wall from one wall type to another wall type ie: 'generic wall' type. Something you're not telling us there. What you may mean is it appears to be 'generic' (grey with not pattern etc)  but a 'generic wall type' is an actuall wall type. I suspect it's one material over writing another becasue they have the same name but different makeup. Not sure, need more details.
Thu, Apr 11, 2013 at 11:57:06 AM | 3D view detail
crosado
thanks for the quick response and for saving me hours of banging my head against the wall. great community here.
Creating an Enlarged Detail View of a Detail I have Drawn
Fri, Aug 31, 2012 at 7:05:29 AM
How do I show a detail callout in more than one view?
Thu, Oct 7, 2010 at 1:22:09 PM
link detail drawing from another drafting view in the same project
Wed, Oct 12, 2011 at 11:14:00 AM
Multiple Detail Numbers In View Title
Mon, Apr 11, 2011 at 12:24:54 PM
CALLOUT DETAIL VIEW VS. PLAN VIEW
Wed, Mar 10, 2010 at 2:04:47 PM
Page generation time: 2.6915
