Forums >> Revit Building >> Technical Support >> windows and panels
Thu, Apr 11, 2013 at 7:49:52 AM | windows and panels
SteveB
3.5 Stars: 5 Votes
Is there a way to make a window and panel assembly like in the pix attached?   The only way I can think is to make a wall with cutouts that I infill with curtain wall.  If curtain wall inerst are the way to go, is there may be a way to insert curtain wall "windows" in curtain walls, which may be schedule-able?
Thu, Apr 11, 2013 at 11:21:37 AM | windows and panels
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Just use a curtain wall and change the glass to be spandrel where you need it.  No need to "make a wall with cutouts" the curtain automatically cuts the wall.  You would schedule the whole curtain wall as one type.
Thu, Apr 11, 2013 at 11:37:15 AM | windows and panels
SteveB
3.5 Stars: 5 Votes
Cutting curtain wall into a stacked wall appears to not work.  Is that your understanding?
Thu, Apr 11, 2013 at 12:08:55 PM | windows and panels
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I'm not having a problem at all.  I just draw the stacked wall first then while still in plan view draw the curtain wall right over the stacked wall.  Then I change the portion of the glazing I don't want clear to a solid.  See attached. Not sure what the problem is, you don't give enough information.
Thu, Apr 11, 2013 at 12:37:38 PM | windows and panels
SteveB
3.5 Stars: 5 Votes
Yes it works.  looks like you have to select it in plan to get at the core CL of the wall.  I just couldn't pick it in 3d iso view
Thu, Apr 11, 2013 at 1:33:33 PM | windows and panels
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
Curtain walls, with spandrel panels. You can make them as complicated and parametric as you like, but it's a fantastic way of controlling dimensions and join conditions between panels.   I have a very low opinion of complicated wall joins across floors...
I have had poor success with stacked walls, and greater success with curtail wall systems.
Here's an example.   Wall, Window+mullion, and spandrel panels nesting perfectly.
Can only square panels in curtain walls be converted to windows?
Wed, May 16, 2012 at 2:22:01 PM
Windows with spandrel panels
Fri, Jul 21, 2006 at 2:57:56 AM
Turning certain curtain panels into spandrel panels
Tue, Dec 3, 2013 at 1:59:47 PM
Panels with Different Finishes on Same Wall
Mon, Jul 8, 2013 at 9:19:13 AM
Windows with infill spandrel/panels
Fri, Jun 15, 2012 at 9:38:54 AM
Page generation time: 1.7443
