Forums >> Community >> Newbies >> Sheet DWG exports appeat PINK in autocad
Wed, Apr 10, 2013 at 7:07:39 AM | Sheet DWG exports appeat PINK in autocad
davidjohansson
Anyone knows why the sheets in my DWG exports appear pink in autocad?
I know its easy to change in Autocad but it would be easier to set this option in Revit.
Thanks
Wed, Apr 10, 2013 at 7:54:45 AM | Sheet DWG exports appeat PINK in autocad
From your HELP:
Create or modify layer mapping to ensure that all the project information stored in Revit categories and subcategories will be exported to the proper CAD layers (or levels, if exporting to DGN). Revit automatically maps categories and subcategories to preconfigured layer names. For example, a Revit door object automatically maps to A-DOOR layer in AutoCAD. You can change the preconfigured layer/level names and modify other export settings. For DGN, the information is saved in text files (see Exporting to DGN); for DWG and DXF, it is saved in export setups (see Exporting to DWG or DXF).
For any of these formats, you can load an existing layer mapping file (current or legacy) and manually change values for it, or you can load layer settings from any of the following mapping standards:
  • American Institute of Architects (AIA)
  • ISO standard 13567
  • Singapore standard 83
  • British standard 1192
Revit Exports DWG Sheet to 0,0,0 not correct coordinates.
Thu, Feb 23, 2012 at 9:43:34 AM
Exporting to Autocad with identical basepoints relative to project
Wed, Jan 14, 2009 at 4:13:11 PM
import autocad sheet to revit
Sat, Jan 17, 2015 at 10:42:33 AM
13
dwg to revit exports as one object
Mon, Mar 17, 2014 at 7:26:48 AM
exporting sheet to autocad
Sat, Oct 22, 2011 at 6:09:49 AM
Page generation time: 2.2148
