Forums >> Community >> Newbies >> Export embeded DWG
Tue, Apr 9, 2013 at 8:13:17 AM | Export embeded DWG
davidjohansson
I have sove linked in objects in revit. When i export out DWGs and for example change the name of the dwg.file. The link gets broken. And the objects that where linked in to Revit dissapears in the dwg.file.
I want my exported DWGs from revit to be without a link. So i can change the name or send the dwg.file to external offices etc.
But i still want to keep the objects that are linked into Revit to be linked, not imported.
Is there a way to do this? Please help.
/D
Tue, Apr 9, 2013 at 8:20:00 AM | Export embeded DWG
Not sure if I understand your question.
Uncheck the box int the export so that it doesn not create x-refs. "Export views on sheets and links as external references"
Tue, Apr 9, 2013 at 8:48:34 AM | Export embeded DWG
davidjohansson
Thats exactly what i mean. Thanks alot you saved my day!
Export 3d DWG issues
Fri, Jun 28, 2013 at 8:27:02 AM
Revit Export to 3D .DWG still will not export Ceiling Grid Hatches?
Wed, Feb 11, 2009 at 4:42:25 PM
EXPORT TO DWG - Problems
Wed, Feb 22, 2012 at 2:28:53 PM
Export Linework colors to DWG
Wed, Sep 14, 2016 at 12:04:12 AM
units for DWG export???
Wed, Oct 19, 2005 at 4:30:00 PM
Page generation time: 0.1757
