Forums >> Revit Building >> Technical Support >> How to add a void through a family
Tue, Apr 9, 2013 at 5:36:55 AM | How to add a void through a family
jpuser
Hi,
I have the attached family of a steel open mesh grating. It was created using several family elements and joining these together. I imported this open mesh to a project with a steel frame. In this project steel columns often pierce through the open mesh grating. I would like to create voids through open meash grating, at column locations so that it looks reasonable.
Would you have an idea how this could be solved? Thanks!
Tue, Apr 9, 2013 at 7:32:09 AM | How to add a void through a family
I think you will find that grating families may kill your project.... at the very least really slow them down.  You are much better off to use a material.  Check out the stock materials that have voids in them to start to understand this process.
Tue, Apr 9, 2013 at 9:02:10 AM | How to add a void through a family
jpuser
It is client's requirement (has to look realistic with all end plate details etc) so cannot avoid it this time. I would appreaciate some help with the voids issue.
Tue, Apr 9, 2013 at 5:55:21 PM | How to add a void through a family
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Make and in-palce void and use cut geometry ?
Tue, Apr 9, 2013 at 8:02:11 PM | How to add a void through a family
ronmalit
5 Stars: 3 Votes
 i would:
-edit the column family and add void into it. (what i usually do is select the solid and paste to same place, then change the solid to void, then lock all the parameters same as the solid.)
-the solid and the new void should be uncut.
-make sure cut with void is ticked.
-then load to the project
-cut the grating and column
** dont be mad, i dont have much... i am homeless
void in family is yellow
Mon, Mar 12, 2018 at 12:22:43 PM
nested void family
Wed, Jul 27, 2011 at 2:52:07 PM
Void Extrusion in window family problem
Mon, May 18, 2015 at 3:55:23 PM
Use Nested Void Family to Cut Host?
Sat, May 28, 2011 at 10:39:48 AM
Void extrusion family visibility
Fri, Apr 22, 2022 at 7:57:52 AM
Page generation time: 2.3011
