13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> Sweap bench around line
1 Posts No Rating |
Hi
First time I used this forum, and I also very new to Revit. Here goes my question:
I downloaded this bench from Revit City, and now I want the back of the bench to follow the circle (figure) I made. Can I just sweep the bench around it, how do i go on from here?
I'm using Revit Architecture 2013
Thanks =)
Where you should go from here is to learn some fundamentals of Revit. Take a course, read some books and at least Read your Help.
Read topics on sweeps.
Was the bench made as a sweep? I doubt it was. All you can do is move and rotate the bench to the position you want it around the area shown.
You could create a profile of the bench and sweep an in-place model around that selected path. However that will give you a solid bench.
Locker/bench combo for 9+ |
Mon, Mar 10, 2008 at 3:01:40 PM
Seat count in bench family |
Tue, Apr 29, 2014 at 10:36:15 AM
Getting away from have Bench Tops/Counter Tops with Parametric holes for Sinks |
Wed, Aug 8, 2012 at 6:51:22 PM
Multiple Curves and Angles with Sweep |
Thu, Jun 6, 2013 at 11:38:07 PM
Can't amend family size in model |
Mon, Mar 19, 2012 at 9:18:12 AM
