24 Users Online (22 Members):
Forums >> Revit Building >> Technical Support >> Wall crossing problem
2 Posts No Rating |
Hello, i got this problem with a stand alone wall i can't figure out.
How do i remove the wall inside the wall in the picture?
We can't help because you don't really tell us anything.
- Look at materials. < Must be same material to join
- Look at wall layer priorities. < A 1 will not join with a 2 no matter what material.
2 Posts No Rating |
Can you tell me exactly what you mean by materials? All of these walls have been tried with same materials on both sides, if thats what you mean?
I attached a new photo to show you what i mean. I want to remove the piece of wall, thats inside the other wall.
What did you do? .... add a masking region? Don't do that.
Model it like you build it. If the crossing wall is one wall, just split into two walls and "trim extend to corner" each half and the 'T' walls..
209 Posts No Rating |
use the wall joins command under modify or pull the wall apart and rejoin them in the order you want.
the problem here are wall layers.
Finish1 vs finish2 vs substrate vs structure.
If walls meet which have matching layers, they will join MUCH more nicely. Otherwise, structure will extend to meet structure, etc.
Help! Revit highligts (floors/roofs/topo) Doesn't allow Crossing Window |
Tue, May 20, 2014 at 10:16:20 AM
Breaking Extension Lines - Crossing Dims |
Sun, Jun 28, 2009 at 11:51:35 PM
Stumped on why window selection or crossing selection wont pick pipe fittings ? |
Sat, Jun 1, 2024 at 1:44:16 PM
How to not have elevation line crossing the model? (level heads on both sides) |
Wed, Aug 6, 2014 at 1:37:02 AM
Bar of a level-crossing |
Wed, May 11, 2005 at 3:26:35 PM
