Forums >> Revit Structure >> Technical Support >> Need HELP!! Geting a Navisworks file inn to Revit Structure
Sun, Apr 7, 2013 at 8:37:06 AM | Need HELP!! Geting a Navisworks file inn to Revit Structure
ekko112
A month ago we got a dwf file from our supervisor for our Bachelor assignment. This is a file originally from Navisworks containing a 3d model of a mud pump. It is now intended that we should get this file into Revit Structure and could then placing it in our 3d model.
I have struggled to get this file into Revit for a while now and was wondering if you might have a solution for me. I'm attaching the two files we are trying to get into the Revit Structure.
Sun, Apr 7, 2013 at 9:29:31 AM | Need HELP!! Geting a Navisworks file inn to Revit Structure
The reason why the files are not attached to your pos are upload, file size limits.  Please pay attention to that.
You need to tell s more.
Sun, Apr 7, 2013 at 9:39:25 AM | Need HELP!! Geting a Navisworks file inn to Revit Structure
ekko112
hmm cant load the files. the size of them are only 88 kb. dont got much info on them will tray and load them up but the only thing i know is that we got the file in dwf form and it is original from Navisworks dont think there are any mark ups on the file its just an mud pump moduel that can only be viewed and not edited.
Edited on: Sun, Apr 7, 2013 at 9:46:17 AM
Edited on: Sun, Apr 7, 2013 at 9:47:02 AM
Sun, Apr 7, 2013 at 9:48:44 AM | Need HELP!! Geting a Navisworks file inn to Revit Structure
ekko112
ok got them up now didn't get up when i tried getting out inn the same time so here is the other one.
Mon, Apr 8, 2013 at 8:02:00 AM | Need HELP!! Geting a Navisworks file inn to Revit Structure
Navisworks is not a modeling program.  It is just a viewer and does not create model files.
DWF's are NOT model files.  They are like a PDF.  Just an iimage - in this case 3D.  Revit will only import markups to DWF's.
You need to get the file in a true model format.
Revit 2010 and Navisworks 2010
Mon, Mar 1, 2010 at 8:15:35 AM
NavisWorks Exporter
Mon, Mar 28, 2011 at 3:40:00 PM
Navisworks or Projectwise for Revit...where to go?!?!?
Sun, Feb 13, 2011 at 6:51:32 PM
Navisworks Question
Tue, Apr 28, 2015 at 1:17:16 PM
Navisworks to Revit
Thu, Aug 25, 2011 at 11:11:37 AM
Page generation time: 2.4404
