Forums >> Revit Building >> Technical Support >> Download files .pat
Sat, Apr 6, 2013 at 3:36:32 AM | Download files .pat
Thread Post Kudo! #1
claudiajovana
4 Stars: 5 Votes
I need help, please. I couldn`t did the download of revit`s patterns. I don`t know what happens. but the files don`t open in revitcity.com.
In aditional, it is difficult to make new patterns in Revit.
Please, someone can help me?
Thanks
Claudia Jovana
Sat, Apr 6, 2013 at 8:00:17 PM | Download files .pat
hugh
3.5 Stars: 4 Votes
What pattern do you seek?
Is it a pattern from RevitCity or from somewhere else?
Hugh Adamson
www.hatchkit.com.au
Sat, Apr 6, 2013 at 11:44:52 PM | Download files .pat
claudiajovana
4 Stars: 5 Votes
Hi Hugh
Thaks for answer me. The pattern is revicity, but I couldn`t make download. All files *.pat is the same thing.
Do you have idea what happen?
Thanks
Claudia
Sun, Apr 7, 2013 at 12:37:03 AM | Download files .pat
hugh
3.5 Stars: 4 Votes
No.
To download a pattern from this site
- log in
- go to http://www.revitcity.com/downloads.php?action=search&keywords=&user_name=&object_file_type%5B%5D=pat&sort=score
- select a pattern file
- select Add file to Zip Cart
- optionally add more files to Zip Cart.
- click on "Download Now"  and save your zip file.
- Open the downloaded zipped file and extact the contained files into a a folder on your machine.
- in Revit, open your project and go the Manage ribbon and select 'Additional Settings' then "Fill Patterns'
- click on 'Drafting' or 'Model' then ''New' button, 'Custom' radio button, 'Import' radio button then browse to your downloaded pattern file(s) and open it(one).
- select a pattern from the  listbox and adjust the scale if necessary to see a preview sample of the pattern.
- click ok,ok to save and use your new pattern from RevitCity.
If you follow the above instructions you should succeed.
If you want to create a new pattern, upload a dimensioned sketch. I'm testing a new version of HatchKit.
Hugh Adamson
www.hatchkit.com.au
Thu, Apr 11, 2013 at 8:09:02 PM | Download files .pat
claudiajovana
4 Stars: 5 Votes
Thanks for help me, but I did what you said to do, but the download didn`t start. I don`t know have idea why....I have other friend with the same problem....
Thu, Apr 11, 2013 at 8:20:59 PM | Download files .pat
hugh
3.5 Stars: 4 Votes
Worked for me.
Why not try asking http://www.revitcity.com/contact_us.php or your systems admin about download permissons?
Hugh Adamson
www.hatchkit.com.au
Fri, Apr 12, 2013 at 3:48:34 AM | Download files .pat
4 Stars: 205 Votes
The problem is in your browser.... right click and "Save as..." (or similar)
Fri, Apr 12, 2013 at 4:33:54 AM | Download files .pat
hugh
3.5 Stars: 4 Votes
Good point.
Some browsers block downloads by default. Some browsers ask for your permission before downloading by popping up a next-to-invisible-if-you-aren't-expecting-it question somewhere (typically near the top of the window) for you to click on.
It is very situation-dependent. Try downloading a file from some other site to see how it's been set up for you and have another go.
Hugh Adamson
www.hatchkit.com.au
Mon, Feb 10, 2014 at 3:32:14 PM | Download files .pat
ameliephaine
In case anyone has trouble with the download issue like I did:
all other families downloaded fine, but nothing would download at all when trying to get the .PAT files.
Right click and "save as" only gave me the option to save as an HTML file.
On the second "Thank you for downloading from Revit City" screen which popped up without a download actually occurring, I *was* able to right click and "Save as" to get the correct download dialogue and save as a .PAT file. Cheers!
Need help with PAT File URGENT!
Fri, Aug 31, 2012 at 8:37:06 AM
Pat Files
Thu, Jan 22, 2009 at 1:26:47 PM
looking for .pat files [ 1 2 ]
Tue, Dec 1, 2020 at 1:43:31 PM
24
Use Pat Files
Tue, Sep 1, 2009 at 4:18:40 AM
11
Is there a way to preview .pat files / hatch patterns in thumbnails in a folder?
Mon, Jul 6, 2015 at 11:01:26 AM
Page generation time: 0.2519
