Forums >> Revit Building >> Technical Support >> Baluster per tread on curved stair
Thu, Apr 4, 2013 at 11:08:47 AM | Baluster per tread on curved stair
stealthnyc
4.5 Stars: 2 Votes
I couldn't find a post elsewhere about this but i'm trying to create a railing (in 2013) that has one baluster per tread.  It works fine on straight run stairs but when applied to a curved stair i don't get one per tread (one on some, 2 on some, in different locations).  Can anyone confirm this?  Thanks.
Thu, Apr 4, 2013 at 1:03:42 PM | Baluster per tread on curved stair
I had no problems doing this with the library stairs.
You can find the stair samples in the on-line library.  Under samples - stairs -
http://revit.autodesk.com/library/html/index.html
Thu, Apr 4, 2013 at 2:11:23 PM | Baluster per tread on curved stair
stealthnyc
4.5 Stars: 2 Votes
Thanks WWhub.  What I forgot to mention is that this is on a 2013 assembled stair.  I am able to get it to work on the regular sketch stair.  Is the stair you are using an Assembled stair?  Thanks again.
Thu, Apr 4, 2013 at 2:18:52 PM | Baluster per tread on curved stair
The stair I show is from a 2010 file so no .... it is not an assembly stair.  Looks like this doesn't work - inform AutoDESK.  (You should also read your 2013 HELP.  It may already say that is not available with an assembly stair.
2015 use baluster per tread on stair (with no top rail?)
Thu, Sep 3, 2015 at 4:50:57 PM
Baluster extensions at bottom of stair runs.
Fri, May 15, 2015 at 9:53:56 PM
adjusting spacing while using "Use Baluster Per Tread On Stairs"
Tue, Sep 1, 2015 at 4:10:58 PM
How to model a non-typical length stair tread for the top tread
Mon, Jan 25, 2016 at 1:55:19 PM
TREAD BALUSTER
Tue, May 21, 2013 at 3:36:03 AM
Page generation time: 0.2462
