Forums >> Revit Building >> Technical Support >> Using Linked files as a floor plate
Thu, Apr 4, 2013 at 1:10:47 AM | Using Linked files as a floor plate
janonliu
Hi,
Doing a high rise building and thought it would be good to have linked files as the apartment types. I can link them in and copy them up etc. is there any way to link them in so they are not referenced to ground level. i.e i I want to but the apartment type on levels 1 to 25, but I drawn the apartment type on ground level. Can I import them into the view, say view 24?
This is only a problem when i schedule them, as it refers to all the types located on the ground floor.
Thanks in advance.
Jan
visibility problem with linked files
Thu, Sep 11, 2008 at 11:52:11 AM
autocad linked files and refresh
Tue, Apr 7, 2009 at 2:12:36 PM
Detach from central - Linked files
Fri, Dec 16, 2011 at 12:50:03 PM
Unable to Place Components in Linked files
Wed, Aug 10, 2011 at 3:11:59 PM
plate not saving
Fri, May 2, 2025 at 1:22:19 PM
Page generation time: 0.4948
