28 Users Online (26 Members):
Forums >> Revit Building >> Technical Support >> Yes/No Parameter (Adding tolerance)
14 Posts No Rating |
I am making a furniture piece for a project that I am doing for my office and The furniture piece has brackets to keep the countertop up. The furniture system changes in length and depending on the length, two of the brackets may or may not be there. I was wondering how I could set a tolerance for the Yes/No Parameter so they go away when the length is below a certain length? I tried putting it in, but they didn't turn off. Anyone know?
11 Posts No Rating |
Create a "Length" Parameter for the overall length.
In the Family Types Dialog Box, in the formula for your Yes/No Parameter, create an equation that reads: Length > X'-X" ...This will turn the parameter ON if it is greater than that length. Make sure you have the Visibily for each bracket set to the Yes/No Parameter.
Ah! I was trying less than, not greater than. That worked. Thank you
Unit tolerance |
Thu, Jan 21, 2010 at 5:12:10 PM
room bounding tolerance |
Mon, Mar 8, 2010 at 2:30:54 PM
pipe annotation tolerance |
Thu, Jan 2, 2020 at 2:21:35 PM
Adding Parameter Groups |
Wed, Apr 22, 2009 at 11:20:10 AM
My wishlist: Adding parameter in VIEW TITLE rfa |
Tue, Mar 20, 2012 at 4:55:00 PM
