Forums >> Revit Building >> Technical Support >> Render on revit
Sun, Sep 14, 2003 at 9:28:37 AM | Render on revit
Tanapong
I beginning start to use revit. I'm interested in parametric 3-D modeling and database technology. my question : Why ray trace render resolution was not so good if I compare with Autodesk VIZ open the same file.? Does Revit can import Autodesk Viz (*.max) directly? if so, Can I use native material assigned by VIZ and render in Revit as well.? (actually I like to link revit files and render in VIZ. so, I can keep revit model/database for further. both are the same Autodesk family should be compatible read/write format hence wihtout Autocad can be work. your comment every much appricated. Regards,
Wed, Sep 17, 2003 at 9:25:07 AM | RE: Render on revit
cnevians
no .. but Viz can import with DWG connection .. works fine.. export in DWG 2000 and import it in Viz or with design extension (max5) but not tested anymore here...
NEVIANS Cedric Architecte DPLG Revit 2011 French User France
Thu, Sep 18, 2003 at 10:55:06 AM | RE: Render on revit
Tanapong
Thanks for reply. my opinion just to avoid repeat assignment material. when I created an object/element on revit mean I choose material already for whole building. then when I'ld like to render clearly on VIZ do I have to did it again.? Uhmm..Export to AutoCAD 14/2000 Does it contain all object properties including material/lighting/camera/etc. I'm just begining to learn revit. sorry, if my question was innocence. anyway thanks again for sharing your idea. Cheers,
Mon, Sep 22, 2003 at 2:08:11 PM | RE: Render on revit
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
Revit can actually do some pretty good rendering, if you have the time to perfect it. Something you can change right away to get better renderings out of revit is to edit the image size of your rendering view. Simply go to the "rendering" tab on the left hand side and click "image size" The default image size is 72 dpi. The higher this number, the better your image will be. Put 150 in here and your rendering will instantly be twice as good. You can also play around with the settings in the "settings" tab. Do you have any more specific questions about rendering? -Hiroshi-
Thu, Mar 9, 2006 at 6:45:06 PM | RE: Render on revit
webios
Yes, it can be pretty, but there's still big difference between renders from VIZ and Revit. I think it's something about Enviroment settings, in VIZ's automatic/logarithmic exposure. But with good radiosity and highest quality it's nice. Do you have any tips or tricks on Revit's rendering? Post edited on 2006-03-09 18:51:57
Revit render or 3ds max design render?
Sun, Jan 4, 2015 at 10:19:29 AM
Any way NOT to render a backround in Revit 2013 ??
Thu, Feb 28, 2013 at 1:00:36 AM
New Render Appearance
Tue, Jul 6, 2010 at 9:45:22 AM
Render goes ok but when i change angle - the render is black
Tue, Oct 20, 2015 at 4:38:11 AM
Revit render solarized?
Wed, Apr 17, 2013 at 9:50:43 AM
Page generation time: 1.3745
