Forums >> Community >> Newbies >> inserting Center to Center
Tue, Apr 2, 2013 at 10:52:12 AM | inserting Center to Center
advacneTEC
Good day eveyone. I have been using Revit for awhile and for the first tme ran into a question on why would you want to use Center to Center insert option when inserting a deg file? Is there a real reason on why we would need to use this other than using orgin to orgin.
AdvanceTEC
www.AdvanceTECLLC.com
Tue, Apr 2, 2013 at 11:01:10 AM | inserting Center to Center
When shared positioning has not been used, I often use center to center then I move the linked(inserted) element manually.
There was a very good article a couple of years ago in AUGI Edge about Revit's origin.  You should look for that.
Center to center as default for importing
Fri, Feb 19, 2010 at 11:01:45 AM
Inserting Links
Fri, Mar 17, 2017 at 7:44:17 AM
Dimension center line of foundation
Thu, Oct 4, 2007 at 7:40:43 AM
dimensioning to a center mark of an arc
Wed, Jul 5, 2023 at 3:13:09 PM
Center Reference Planes.......
Tue, Jan 30, 2018 at 9:48:46 AM
Page generation time: 0.1172
