Forums >> Revit Structure >> Technical Support >> Copy/Monitor walls
Tue, Apr 2, 2013 at 10:10:07 AM | Copy/Monitor walls
mark7321
When I copy a wall from an Architect's model using Copy/Monitor it doesn't show on my plan. I tried to Copy / Monitor it again and it says it's already been copied. I have the architectural model set to halftone to make it easy to see the copy / monitored wall show up as a dark, structural wall after I click the green check mark to complete the copy / monitor process. My floor plan is set to "Structural" as the Discipline in the Properties box. Is there another setting I'm missing?
Tue, Apr 2, 2013 at 10:12:09 AM | Copy/Monitor walls
Change your discipline to coordination.
Tue, Apr 2, 2013 at 10:14:23 AM | Copy/Monitor walls
mark7321
That worked. Thank you.
Copy/ Monitor walls in 2011 or 2012
Thu, Jul 14, 2011 at 1:24:43 PM
best practice for copy/monitor
Sun, Dec 12, 2010 at 5:07:02 PM
Copy/Monitor Lights to Revit Architecture 2012
Wed, Oct 17, 2012 at 3:05:52 PM
Copy Original Type Not Available in Copy Monitor Options Dialogue
Fri, Nov 6, 2015 at 2:16:27 PM
Can't Get Copy Monitor to Work for Grids and Levels
Fri, Feb 21, 2014 at 4:55:28 PM
Page generation time: 0.4040
