Forums >> Revit Structure >> Technical Support >> My beam i designed is wider than my column
Tue, Apr 2, 2013 at 5:54:51 AM | My beam i designed is wider than my column
kguy289
I have a UKB 356x171x54 beam connecting to a UKC 152x152x44 column. The beam is to connect to the 'tw flange' part.
Not sure what to do as i have to produce drawings showing the connections. I have already calculated and designed the columns, beams, and their connections.
Tue, Apr 2, 2013 at 8:16:41 AM | My beam i designed is wider than my column
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Is this a Revit question or a how to construct question?
How to extend top flange of beam (over top of column)?
Fri, Jun 15, 2012 at 10:35:08 AM
How to show beam column connection in plan properly
Fri, Nov 7, 2014 at 12:53:30 PM
Tee beam as column?
Tue, Nov 6, 2012 at 2:41:46 PM
beams not snapping to beam/column
Fri, Feb 19, 2010 at 4:30:22 PM
Column Family/Beam Family
Fri, Aug 27, 2010 at 1:25:52 PM
Page generation time: 0.5534
