Forums >> Revit Building >> Technical Support >> piping help
Tue, Apr 2, 2013 at 1:18:54 AM | piping help
frifer
5 Stars: 4 Votes
Hi guys!
i never really used piping up to now, (except for some testing without success) but the time has come that i need it and i am not even able to start with it.
when i draw a line i only see the line without seeing the pipe and each time i make a curve i get a error message saying that there are no compatible fititngs.
i guess it is like this because i havn't set up a pipe type.
so in the browser i selected pipes, pipetypes rightclick on standard , duplicate and tried to change its settings. but even with that it doesnt work. i can only make the first line and after that line i can click how much i want and nothing happens.
what i would need is to draw a simple piping without flanges or anything like that. just a tube with curves Tees reductions where needed etc.
any help appreciated..
thanks
Frifer
Check out my new Renderlist add-in to render multiple views in sequence overnight! Get it here and remember to leave some feedback Shadey http://www.revitcity.com/forums.php?action=viewthread&thread_id=28381
Tue, Apr 2, 2013 at 8:14:57 AM | piping help
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You need to load the connections you need.  Also change your view display from coarse to medium or fine to see more than just a line.
Tue, Apr 2, 2013 at 8:38:41 AM | piping help
frifer
5 Stars: 4 Votes
That did the trick!
thanks! Smile
Piping loops
Wed, Apr 30, 2008 at 12:35:59 PM
Connecting Sanitary Piping
Thu, Dec 13, 2012 at 3:42:23 AM
Adding materials to piping systems
Mon, Oct 12, 2009 at 4:07:42 PM
REVIT for process piping spool drawings?
Mon, Mar 5, 2012 at 1:54:09 PM
Piping to a project with links.
Mon, Apr 6, 2009 at 9:25:57 AM
Page generation time: 0.7228
