Forums >> Revit Building >> Technical Support >> Linked Models
Mon, Apr 1, 2013 at 8:47:35 AM | Linked Models
kipchura
Very new to revit, trying to get an understanding so bear with me.
I would like to set up a new project for MEP coordination. My question/issue is this:
If I open a new arch model and detach from central I have full comntrol/access over model as far as display settings, hiding layers and such. If I create an MEP new project and link in the model I lose that control. I cannot for instance "Hide" the "Furniture" on a floor plan. The options are greyed out.
Is this normal or am I doing something wrong? How do I control the visisbility of a lionked file?
Thanks,
Don
Mon, Apr 1, 2013 at 8:53:54 AM | Linked Models
Linked model VG is controlled per view in VG......You will see a seperate tab for linked files, then new VG settings for each file.
Mon, Apr 1, 2013 at 9:57:26 AM | Linked Models
kipchura
I am in the Revit Linked Tab and all of the options are greyed out.
See attached screen shot.
Mon, Apr 1, 2013 at 10:44:02 AM | Linked Models
On the main line of that "Test model" - click on the "By host model" - change it to custom - then in the model tab - change that to custom and do what you want.
BTW - you should also turn off the linked files annotative items like grids and levels.
Mon, Apr 1, 2013 at 9:50:48 PM | Linked Models
RevitBJO
For what it's worth, view template 'discipline' affects what you see in your view too. When I link files in for coordination I have my view discplines are set to 'coordination'.
'Linked' views can be useful if you want to overlay a specific view over your own view...for whatever reason.
Cheers,
Tue, Apr 2, 2013 at 6:44:49 AM | Linked Models
kipchura
Thank you all for your help, it's starting to make some sense now.
Tue, Apr 2, 2013 at 7:55:04 AM | Linked Models
Because you are new to Revit, you may not know that Revi's HELP is very good.  The problem is how to search it.  Use simple, one word searches, then modify as needed.  Searching linked gets you this topic which would have explained all of this to you.
Using Custom Settings to Display Linked Models
Tue, Apr 2, 2013 at 6:35:43 PM | Linked Models
kipchura
Thanks. I'll check out the help section.
View Filters and Linked Models
Tue, Mar 28, 2017 at 7:53:31 PM
Linked Models - Element / Component Identification
Tue, Dec 7, 2010 at 4:10:55 PM
Linked Model - Losing only some doors from linked model
Thu, Oct 21, 2010 at 1:52:14 PM
Referencing Callouts in linked models
Wed, Jul 3, 2013 at 12:02:20 PM
sheet index order with Linked models
Sun, Mar 13, 2016 at 12:37:27 PM
Page generation time: 0.2125
