Forums >> Revit Building >> Technical Support >> Building Not Showing in North/West Elevations
Fri, Mar 29, 2013 at 2:27:08 PM | Building Not Showing in North/West Elevations
carabridget
For some reason my entire building is no longer showing in my North and West elevations.  However, it is showing in my South and East elevations.  Any idea how to fix this?  I checked the phase filter and phase and they are the same in all views.  My far clipping is set to no clip.  I am using the student version 2013.  Any ideas on how to fix this?
Thu, Jan 23, 2014 at 5:45:31 PM | Building Not Showing in North/West Elevations
raja15
Hi carabridget.
Simple question, but have you checked the crop box location in relation to your 3D model?
It could be that the model itself is outside of the crop box and that is why it's not showing on your views.
Hope this helps.
Fri, Jan 24, 2014 at 1:31:58 AM | Building Not Showing in North/West Elevations
mansell5
3.5 Stars: 4 Votes
in floor plan view click on the elevation marker to show the extent lines, ie the solide line and the dashed lines which indicate view depth.
Mon, Aug 18, 2014 at 11:44:38 AM | Building Not Showing in North/West Elevations
isa115
Switch to the elevation which is not appearing -> in the Graphics table on left side set the 'View Scale' to a smaller scale, lets say 1:100. It worked for me!
Revit only showing 2 elevations
Sun, Apr 10, 2016 at 10:22:54 PM
Building Elevations Looking Flat
Fri, Jan 11, 2013 at 11:00:44 AM
How to Rotate True North without rotating the whole Project?
Thu, Mar 18, 2010 at 7:25:35 PM
Finish Schedules, Finish Elevations and Plans
Thu, Dec 16, 2010 at 2:52:44 PM
Project North & True North
Thu, Mar 5, 2009 at 5:02:49 PM
Page generation time: 0.5500
