12 Users Online (10 Members):
Forums >> Revit Structure >> Technical Support >> Working on a linked file
22 Posts No Rating |
scenario:
- I am given a project file (OTHER) from a client
- I will link OTHER into my file (HOME)
- my job is to populate the walls of OTHER with studs using a revit add-in (Metal Wood Framer)
- basically, HOME will have the studs that belong in OTHER and when the two files are combined there should be no clashes
can i work on individual parts of the linked OTHER, or will my only option be to do all of my work directly on OTHER and not link it?
A link is a link - you can not edit a link, you can only edit the file you are working in.
Working with linked files |
Thu, Oct 6, 2005 at 8:17:08 AM
Linked File Issue |
Mon, Oct 14, 2013 at 7:32:33 AM
edit linked file in place or at least open linked file withou having to unload |
Fri, Dec 4, 2009 at 9:57:47 AM
Linked File, how can I dimension it? |
Sun, Dec 19, 2010 at 8:08:50 PM
How to make room tags in a linked file visable? |
Thu, Jul 30, 2015 at 1:12:22 AM
