Forums >> Revit Building >> Technical Support >> Shared Parameters
Tue, Jan 31, 2006 at 3:00:09 PM | Shared Parameters
arccodex1
3 Stars: 1 Votes
Should I develope a shared parameters file for use in ALL projects or should shared parameters be project specific? Maybe everyone can exchange what Shared Parameters they have set up and for what reason. I'll start: Name: Height Offset From Level Type: Text Usage: For adding Ceiling Height to Room Tag Post edited on 2006-01-31 15:19:32
Sun, Feb 5, 2006 at 10:57:05 AM | RE: Shared Parameters
Dgodfrey
4 Stars: 4 Votes
I'm just looking into shared parameters to see if it would allow me to provide the room name that specific windows are located in the window schedule so that i may extract the required light/vent & egress using the area function. sorry i can't provide any insight to your dilemma but i'd be curious on how you added the ceiling ht. to the room tag as it may give me a jump start. tx
Thu, Feb 9, 2006 at 1:41:58 PM | RE: Shared Parameters
arccodex1
3 Stars: 1 Votes
I just created a new parameter for ceiling height and manually type in the ceiling height I want for the room. Then I ad a label to the Room tag that links to the new ceiling height parameter. I would prefer to be able to use the ceiling height parameter that's used on the ceiling tag (in essence creating a hybrid room tag/ceiling tag) but I couldn't figure it out.
Shared or Project Parameters?
Tue, Jan 19, 2010 at 7:01:11 PM
Project Shared Parameters or Shared Parameters in Families
Fri, Feb 21, 2014 at 10:22:42 AM
Creating Shared Parameters
Tue, Nov 25, 2008 at 4:45:08 AM
Shared Parameters File is not a valid...
Wed, Feb 12, 2014 at 9:31:26 AM
Shared Parameters Workflow
Tue, Sep 21, 2010 at 7:53:53 AM
Page generation time: 1.4116
