Forums >> Community >> Newbies >> Workset Management
Thu, Mar 28, 2013 at 12:57:02 AM | Workset Management
RevitBJO
I've worked on a number of BIM/Revit projects where Workset Management has been very important for one reason or another. I wondered what peoples thoughts were on a good & efficient Workset Management system that ensures everything all elements are kept on the correct workset before the model is issued.
My current system:
I set 3D working views up that have filters applied. Say I want all elements on L1 to be on the L1 workset (as an example). I'd have a filter that says 'if not equal to' 'L1' make it's surface and cut patterns red. Then in my 3D I visibly see if a another user has missed something. Obviously you can grab and filter all elements and bulk change them to the correct workset..sometimes..though I this appears to be a more full proof way.
Does anyone else have any other suggestions ?
Thu, Mar 28, 2013 at 7:00:31 AM | Workset Management
While I do like worksets ... I totally agree with what Steve Stafford writes here:
http://revitoped.blogspot.com/2012/04/how-many-worksets-do-i-need.html
If you have to do a lot of special things to manage your worksets, you may have too many.
Mon, Apr 1, 2013 at 5:18:37 PM | Workset Management
RevitBJO
Good article and for the most part I agree with the items raised. I would not use worskets to control the visibility of categories and would only use them to control visbility when filters are not the best option. Primarly they are used to save RAM.
I only ever use a few worksets, though this still needs to be managed and it's easy for users to place elements on the wrong workset.
Default Workset
Sun, Sep 25, 2016 at 12:01:18 AM
Saving/unlinking a Workset Without Updating
Wed, Oct 1, 2008 at 12:24:51 PM
Does Revit support Facility Management?
Mon, Dec 4, 2006 at 10:18:50 PM
Pipe visibility / workset problem
Thu, Dec 22, 2011 at 9:02:36 AM
Any way to set up certain workset to be gray?
Wed, Dec 8, 2010 at 3:23:00 PM
Page generation time: 0.4503
