Forums >> Revit Building >> Technical Support >> Wall Sweep at the Corner
Mon, Mar 25, 2013 at 12:25:30 PM | Wall Sweep at the Corner
frankmm
Hello,
I am working in Revit Architecture 2013. I have various wall profiles/heights that I applied wall sweeps to to show coping. I am trying to figure out a way to make the wall sweep go over the corner or miter. How can I do that?
Thank you,
Margaret Frank
Mon, Mar 25, 2013 at 12:41:21 PM | Wall Sweep at the Corner
When you add wall sweeps, continue the process - don't start over on each wall.  Then they will miter automatically.
So - delete all but one sweep, then pick that sweep and select add wall - on your options bar.
Mon, Mar 25, 2013 at 12:45:45 PM | Wall Sweep at the Corner
frankmm
Some of my walls are angled though. If I didn't model those in-place, I wouldn't get the angle, right?
Mon, Mar 25, 2013 at 12:59:07 PM | Wall Sweep at the Corner
There are more than one way a wall can be angled.....
Obviously, if you can't place the sweep on the wall because it is angled (whatever way you mean) then the automatic miter at the corner can't happen.  You have to model whatever you want.
Mon, Mar 25, 2013 at 1:01:41 PM | Wall Sweep at the Corner
frankmm
I have walls that slope downwards. How would I go about modeling this manually?
Mon, Mar 25, 2013 at 1:20:45 PM | Wall Sweep at the Corner
I suppose you mean the wall is not vertical - correct?
You can do an in-place sweep.  And an in place can have its path set to wrap a corner.
wall sweep inside corner
Mon, Dec 18, 2006 at 9:07:04 AM
Corner Trim with Vertical Sweeps
Thu, Aug 31, 2017 at 2:32:51 PM
how to make a corner sweep
Mon, Apr 18, 2011 at 12:00:49 PM
Corner guards to snap to corner of wall
Tue, May 13, 2014 at 12:18:44 PM
stacked wall sweep cleanup
Fri, Feb 12, 2010 at 9:11:19 AM
Page generation time: 1.5174
