Forums >> Revit Building >> Technical Support >> Wall Sweeps not showing up in phase
Mon, Mar 25, 2013 at 10:46:05 AM | Wall Sweeps not showing up in phase
Archispaz
Working on a project which has multiple phases and after completing the model the client determined they would like to create a new phase and add it before all of the other phases. So I went through and switched all the items that had been selected to move up to this new phase. After doing so and adjusting the phase filter in the view all of the wall sweep disappeared.
The wall sweep are apart of a stacked wall and if I copy one of these walls in the phase I moved them to the wall sweep shows up on the copied wall. However the original wall that was moved to this new phase still does not show the wall sweep.
Any thoughts?
Angling Wall Sweeps
Mon, Aug 15, 2011 at 1:26:41 PM
Showing a Phase 1Section Tag in a Phase 2Plan
Wed, Nov 30, 2011 at 12:33:13 PM
Wall Sweeps in Visibilty Graphics
Wed, Jan 20, 2010 at 12:10:08 PM
Walls with automatic wall sweeps
Fri, Aug 31, 2012 at 3:58:55 AM
Outlets and Wall Sweeps
Wed, Feb 29, 2012 at 9:39:46 AM
Page generation time: 0.9043
