Forums >> Revit Building >> Technical Support >> Solid fill walls REVIT 2013
Sun, Mar 24, 2013 at 5:18:20 PM | Solid fill walls REVIT 2013
joeinck
So, how do you make a solid fill pattern in 2013?
thanks
Mon, Mar 25, 2013 at 7:51:42 AM | Solid fill walls REVIT 2013
Same as you did in 2008,09,10,11,12.  In your dropdown pick a solid then your color.
Mon, Mar 25, 2013 at 4:11:24 PM | Solid fill walls REVIT 2013
joeinck
thanks, your right, but I was not expecting to do it via the material editor. a little different.
Revit Arch. 2009 - Floor Plan Solid Fill blocks out walls
Mon, Mar 30, 2009 at 2:22:09 PM
Solid Drafting fill pattern
Tue, Jun 23, 2015 at 1:35:01 PM
Solid Fill Pattern
Wed, Jan 9, 2008 at 1:55:24 AM
Solid Fill Hatching
Tue, Dec 13, 2005 at 7:11:20 PM
Bearing walls solid fill
Tue, May 17, 2005 at 10:54:56 AM
Page generation time: 1.7069
