15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> Residential remodel not plotting as shown on sheets
Can anyone tell me why my existing walls show up fine in my sheet but don't plot to .pdf
I have the view range settings set correctly and all other sheets plot fine.
I thought maybe the roof transparency was the issue but
Revit is usually pretty much a WYSIWYG plotting operation and the walls are displaying in the sheet file.
Not sure what I'm missing here.
I'm in 2013.
Please see attached files.
Thank You.
If that is an underlay, do you have your halftone set too low to print?
Underlay is set to none. view range is set to slab. It should print as it shows on the screen and it's not.
I did however get a reply in another forum to try plotting at Raster setup instead of vector and I did, and it worked.
I still consider that a workaround since it should plot as displayed anyway.
All other sheetgs plot fine. I thought the roof transparency needed to be adjusted but that wasn't the case either.
Thanks WWHub
Remodel confusion |
Wed, Jul 8, 2009 at 3:33:57 PM
Setting a project up to easily plot between different sheet sizes/plotters |
Sun, Jul 18, 2021 at 10:22:33 AM
Some sheets plotting rasterised for no reason - revit building 2013 |
Thu, Jan 30, 2014 at 7:16:15 AM
plotting sheets from a linked model |
Thu, Oct 16, 2014 at 11:11:01 AM
Plotting output clipped at top and bottom using Savin 2400 |
Mon, Mar 30, 2009 at 8:51:38 AM
