Forums >> General Discussion >> Revit Project Management >> Custom Elevation Marker
Fri, Mar 22, 2013 at 2:50:31 PM | Custom Elevation Marker
ivanjay205
Hello all,
I am trying to edit the default spot elevation tag to customize to our views.  What I want to do is add the word AFF after the dimension automatically and place a text box below the elevation so that the drafter can type up a description.  For example for a counter height I want to have:
2'10" AFF
______________________________
Countertop
Mon, Mar 25, 2013 at 7:48:53 AM | Custom Elevation Marker
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You can add a prefix or a suffix to the spot elevation through the properties of the marker.  The spot elevation is a systems family an you cannot add a label to the family to get it to read "countertop" underneath.
Mon, Mar 25, 2013 at 9:55:09 AM | Custom Elevation Marker
ivanjay205
Is there a way to make my own elevation marker or I have to use what is built into revit?
Text Orientation in Custom Elevation Marker
Fri, May 6, 2011 at 10:36:12 AM
Split a an elevation marker up for mulitple sheets
Tue, Oct 4, 2016 at 2:29:34 PM
Adding a reference elevation to an existing elevation marker?
Wed, Sep 17, 2014 at 7:57:46 AM
ELEVATION MARKER
Thu, Sep 10, 2009 at 2:55:39 PM
If your elevation markers on plan disappear.
Fri, Mar 4, 2016 at 3:40:45 PM
Page generation time: 0.3796
