Forums >> Revit Building >> Technical Support >> Detail Groups vs. Families - pros/cons?
Wed, Mar 20, 2013 at 10:17:08 AM | Detail Groups vs. Families - pros/cons?
Van2010
Can anyone comment on the pros/cons of generating detail groups versus detail component families, besides scheduling and tagging. I am trying to convince people it is better to always create families.
Thanks.
Wed, Mar 20, 2013 at 10:45:10 AM | Detail Groups vs. Families - pros/cons?
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I'm not sure what you mean besides detail groups?  If you are making groups of your details then they are already families right?  Or are you asking the difference between detail components and just drafting lines
Wed, Mar 20, 2013 at 10:51:53 AM | Detail Groups vs. Families - pros/cons?
Detail families are easier to load into projects.
Detail families can be parametrically controlled.
     (We use one for storefront mullions that can change size and has parametric "glass" lines - similar one for door frames)
Detail families can have flippers - no need to mirror.
Detail grouping may include detail components
Use detail families for definable elements that will be used in multiple projects.
Detail groups can be used as defined for multiple locations with single place editing but they can also be used to get a group of elements "near" where you want them then ungroup to correctly place as individual elements.  << Sort of a template of required elements.
Groups VS Nested Families
Mon, Apr 20, 2009 at 10:49:07 AM
Control Files, Pros and cons
Tue, Dec 6, 2011 at 3:53:26 AM
Drafting Details - Detail Components vs Groups
Sun, Nov 13, 2005 at 5:56:12 PM
Autocad MEP imported into Revit MEP Pros/Cons
Fri, Jul 22, 2011 at 1:08:45 AM
Revit MEP or AutoCad MEP
Fri, Oct 14, 2011 at 7:55:24 AM
Page generation time: 4.6814
