Forums >> Revit Building >> Technical Support >> Import DWG into Detail Plan
Wed, Mar 20, 2013 at 7:51:12 AM | Import DWG into Detail Plan
frankmm
Hello,
I'm working in Revit Architecture 2013. I am trying to insert a DWG file into a detail plan. I made sure all my visibility options are on as well as changing the view depth to unlimited. It does not come up if reveal hidden elements either. Is it even possbile to insert a DWG into a detail plan? If so, how do I go about that?
Sincerely,
Margaret Frank
Wed, Mar 20, 2013 at 7:54:10 AM | Import DWG into Detail Plan
frankmm
It does, however, show up in the overall plan.
Wed, Mar 20, 2013 at 8:55:42 AM | Import DWG into Detail Plan
Some suggestions.
Whenever possible, link - don't insert.
             - And place in a separate workset set to be typically off in all views.
Are you working from an activated sheet view?  < Don't  -  Always work from a view.
You say detail view - I assume created by call out in plan - not a floor plan created by call out.  There is a difference in what shows up in these two view types.
dwg import bring to front
Fri, Jun 27, 2008 at 9:46:56 AM
Import DWG problem with size
Mon, Dec 6, 2010 at 7:33:32 PM
Can't import dwg or dxf to RS2008
Wed, May 30, 2007 at 10:36:07 PM
import & explode dwg detail
Tue, Nov 28, 2006 at 10:08:04 AM
Dwg Site Import
Tue, Feb 21, 2006 at 5:12:40 PM
Page generation time: 0.5677
