18 Users Online (16 Members):
Forums >> Revit Building >> Technical Support >> Revit 2013: Family Materials Graphics vs Appearance
7 Posts No Rating |
I've got a family that has a custom finish in it. I've checked the option to have the graphic property color matched to the rendered appearance. After realizing I had to adjust the asset to make it work inside the family I loaded the family into the project only to have the graphic color property switch to 0,0,0 (black). Any thoughts as to why this would happen?
Other items to consider:
I'm using a material type parameter so that I can have various finishes preset.
THE PROJECT RULES
No matter what you do in a family, if the material is already defined in the project, then that is what is used. Once a material is loaded into a poroject by way of loading a family, that material remains until deleted.
2013 Revit Materials |
Mon, Oct 8, 2012 at 8:43:00 AM
Can the appearance of materials change by view type? |
Wed, Aug 5, 2015 at 4:04:02 PM
Bumps for materials - where is the setting in 2013 |
Mon, Jul 16, 2012 at 2:48:23 AM
REVIT 2013 Materials Library Video Tutorial |
Tue, May 28, 2013 at 5:12:56 AM
13
Adding New Materials to the Render Appearance Library in RAC 2009? [ 1 2 3 ] |
Fri, Aug 8, 2008 at 6:11:21 PM
31
