20 Users Online (18 Members):
Forums >> Community >> Newbies >> Sheets on DWG exoprts
61 Posts No Rating |
When i export DWGs from Revit 2013 i don´t get the sheets. Only the building it self.
How do i get the full sheet whit info, text etc. in DWG format?
Thanks.
/D
Are you exporting from a sheet view and your sheet is what you have picked to export?
Note - If you don't uncheck the box "export views on sheets and links as external references" then you will get dwg's of your views and they will be x-ref'd into a seperate dwg of the sheet.
DWG sheets to RVT |
Sun, Jun 9, 2019 at 10:57:52 PM
Exporting sheets to dwg with shared coordinates |
Tue, May 6, 2008 at 9:50:37 PM
Sheets exported to DWG |
Tue, Jan 15, 2008 at 5:42:15 PM
converting sheets to dwg. |
Fri, Jun 25, 2004 at 11:02:17 AM
exporting to dwg |
Wed, Aug 18, 2010 at 5:10:21 AM
