Forums >> General Discussion >> Revit Project Management >> Numbering the stations in property lines
Tue, Mar 19, 2013 at 4:52:18 PM | Numbering the stations in property lines
Ricardo8123
Is there  a way to put numbers sequentialy in each prop line intersections. I meant some like E-1, E-2, .... and so far and make this numbers be schedulable?
Thanks for help I'm desperate
Wed, Mar 20, 2013 at 7:23:57 AM | Numbering the stations in property lines
You can create a family with a shared parameter that can be scheduled and tagged but there is no built in way of numbering sequentially.
Wed, Mar 20, 2013 at 7:46:12 AM | Numbering the stations in property lines
Ricardo8123
Thanks for your response. I tried to do so, but, dont know what templates choose or kind of paramenter.
Sorry I'm a beginner in Revit. Do you know where can I get information about creation of this kind of family?
I really apreciate your help. and thanks again
Wed, Mar 20, 2013 at 8:27:01 AM | Numbering the stations in property lines
You need to do some learning.
First read up on shared parameters and how to create them in your help.
The family can be a simple non-hosted element with a line to place at the station point. << Detail template
You can create a tag that "reads" a shared "station" property in the family.
Then you can array these (and a tag) along your line and set the station value for each afterwards.
Wed, Mar 20, 2013 at 1:28:50 PM | Numbering the stations in property lines
Ricardo8123
I thanks you again for your help. You are very kind and patient. I'll try what you have said to me and thanks again
Gratefully greetings
Property Lines + True North Rotation
Thu, Apr 26, 2012 at 2:34:45 PM
Stair numbering
Tue, Feb 27, 2018 at 4:34:51 PM
Property Lines on Toposurface
Mon, Jul 9, 2007 at 10:22:49 AM
property lines hidden by topography
Tue, Mar 6, 2007 at 11:47:47 AM
Progataing property lines to floors
Fri, Mar 18, 2011 at 4:25:43 PM
Page generation time: 0.4580
