Forums >> Revit Building >> Technical Support >> I want roof structure layer to be transparent so rafters tails appear.
Mon, Mar 18, 2013 at 6:16:34 PM | I want roof structure layer to be transparent so rafters tails appear.
dgferriday
I'm want to show exposed roof truss rafter tails, so I don't want roof truss/joist material layer to show up as solid. How do I do this? (I want to keep the plywood and roofing material layers solid.)
Tue, Mar 19, 2013 at 9:11:56 AM | I want roof structure layer to be transparent so rafters tails appear.
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
What exactly are the layers of your roof?  Your saying you have one thick roof say 2' thick that includes your roofing material, plywood and trusses?  You aren't going to be able to do what you are trying to from what I gather.  If you have roof trusses I would actually put the roof truss family in. Then I would have the actual roofing construction as its own roof.  Another option would be to have 2 roofs, one with the roof truss/joist layer and another with the rest of the roofing layers and in your view override the graphics by element for your roof truss/joist layer and change the transparancy. The only other thing I can think of is to create a material for your roof truss/joist layer and make the actual material have some transparancy however this would affect all views.
exposed rafter tails
Mon, Aug 4, 2008 at 7:24:34 PM
How to create Sloped Rafters with Various Rafter Tail Cuts
Mon, Jul 22, 2013 at 12:25:53 PM
Roof Rafters exposed
Mon, Oct 1, 2007 at 9:08:11 AM
drawing angled roof rafters
Tue, Aug 18, 2009 at 11:53:17 AM
rafters
Fri, Feb 13, 2009 at 5:30:08 PM
Page generation time: 1.6548
