28 Users Online (26 Members):
Forums >> Revit Building >> Technical Support >> cant cancel print to pdf bluebeam
I have had a longstanding problem with Bluebeam: If I print from revit to compbine multiple drawings into a set, and the set has more than +/- 4 drawing to it, the print routine prints the 1st set and will then continue to print OVER AND OVER again. It seems to do it the same amount of times as there are drawings in the set. 20 sheets... 20 sets! It takes a half and hour+++ and you can't cancel it seemingly THOUSANDS of times or else by crashing Revit. Really primative stuff. I have read another non-Bluebeam user that had the same print to pdf problem so I am only guessing the problem is in Revit, not bluebeam.
Anyone know a fix for this?
Props to Bluebeam tech support. They removed an install conflict via screenshare and looks like the problem is solved.
Print to PDF sheets with DWG files on them help. Maybe Bluebeam help |
Mon, Oct 26, 2015 at 10:55:35 AM
Bluebeam vs. Adobe |
Wed, Nov 13, 2013 at 7:19:54 AM
Incompatibility between ''Bluebeam'' pdf fillar and Autocad dwg. |
Wed, Aug 19, 2020 at 7:59:03 AM
Dear Mr Autodesk |
Tue, Apr 13, 2010 at 7:23:45 AM
Wall Solid Fill Cut Pattern Jagged on PDF |
Fri, Apr 3, 2015 at 10:36:32 AM
