Forums >> Community >> Newbies >> View Template
Mon, Mar 18, 2013 at 3:12:03 PM | View Template
althouse08
I have changed the default template to my company's, however the lettering is not parametric with project parameters. Is there a way to set this up so that I only need to insert project information once?
"The road to success is always under construction"
Mon, Mar 18, 2013 at 3:15:05 PM | View Template
Sorry but your question is not at all clear.
What template?  Assuming project <<<<Sorry - I just re-read your subject.
"...lettering is not parametric with project parameters"...  << I haven't got a clue as to what you are saying
Project information..... Use the standard shared parameters.  These can be used in sheet families.
Edited on: Mon, Mar 18, 2013 at 3:16:39 PM
Tue, Mar 19, 2013 at 10:29:00 AM | View Template
althouse08
I mean when I print my sheets using the standard revit border, all the information is placed automatically based on the project information entered at the start of the project. If I use my own custom border, then the information isn't entered automatically. Sorry I wasn't very clear about that. I am looking for a way to make my custom border automatically place project information. Also with that, I am trying to get all the fonts, symbols, and standard annotations to match what my company already has in place in AutoCAD.
Tue, Mar 19, 2013 at 10:56:14 AM | View Template
Edit your sheet family and use the shared project parameters.  It appears that you don't understand these so read up on shared parameters in your HELP.
You can learn how title blocks work by editing the default titleblock and looking at the parameters used.
Be aware that Revit is not CAD.  Many of your CAD standards may have to change and in most cases, it will be for the better.
Tue, Mar 19, 2013 at 1:21:15 PM | View Template
althouse08
Ok thank you very much. I do not know anything about shared parameters so I will read up on them.
view template applied to each placed view
Thu, Jul 2, 2015 at 2:36:37 PM
Which View Template am i working with?
Tue, May 10, 2016 at 12:31:40 PM
Revit 2015 View Template Linked Vew resets to None Hiccup
Tue, Jun 28, 2016 at 4:50:06 PM
View Template with automatically annotated families
Mon, Oct 27, 2014 at 3:50:30 PM
Workset VG in View Template
Mon, Nov 24, 2008 at 8:27:08 PM
Page generation time: 3.5258
