Forums >> Revit Building >> Technical Support >> Toposurface in Elevations
Mon, Jan 30, 2006 at 11:14:27 AM | Toposurface in Elevations
kesflower
3.5 Stars: 11 Votes
I'm trying to figure out how to make my toposurface show up as only a grade line in elevations. Instead of the toposurface showing me a solid line with earth hatch below, I want a dotted grade line and no hatching below. Is there a checkbox or something simple that I am missing? Is that a property of the toposurface that I need to change when I create it? Thanks for any answers or help. Ruth
Mon, Jan 30, 2006 at 11:46:19 AM | RE: Toposurface in Elevations
josta
1 Stars: 1 Votes
I had the same situation; I used the "lines" function to change the underground lines to a dotted line, or you can even change it to invisible lines. JOHN
Mon, Jan 30, 2006 at 7:12:28 PM | RE: Toposurface in Elevations
arccodex1
3 Stars: 1 Votes
Go to settings... site settings... section cut material... no material
Wed, Jan 3, 2007 at 11:56:48 AM | Toposurface in Elevations
JesseGLY
I went into site setting and checked no material but in my section veiw everything below the toposureface is blocked out where is used to show a hatch pattern is there a way to change this to show everything below?
Thu, Aug 27, 2009 at 1:51:06 AM | Toposurface in Elevations
rudyard
1 Stars: 1 Votes
Go to your elevation, select the toposurfce, right click and select 'override graphics in view' and then select 'element', click 'surface patterns' and then uncheck 'visible'.
RAC 2009, dont know about earlier versions.  My first non question post!
Anyway to attach wall bases to toposurface??
Sun, Dec 31, 2006 at 9:23:21 AM
Using Survey Data to create a toposurface
Mon, Oct 4, 2010 at 2:23:28 PM
Toposurface level wrong to Co-ordinates
Tue, Mar 3, 2015 at 7:38:02 AM
Toposurface Elevation
Mon, Mar 26, 2007 at 8:03:00 AM
Toposurface point reporting
Sun, Feb 2, 2014 at 2:18:35 PM
Page generation time: 0.4229
