11 Users Online (9 Members):
Forums >> Revit Building >> Technical Support >> Error Message when i try moving curtain wall in a group
I made a group for the exterior skin that repeats on about 6 floors of my building. The building got 2'6" longer and when i go to edit the group, i cant because of the error message. any idea why?
Selection cannot be copied.
Mullions and panels cannot be copied without copying the entire curtain wall.
I think that error message is self explanitory. Don't copy or group CW elements - just copy or group the wall.
if it was that self explanitory i wouldnt have asked.
all thats grouped are the walls. not the pieces of the curtaiwall.
i dont get any errors when i select the group. its only when i go to move the curtainwall or if i try to edit the group and add a new mullion, then try to save it, i cant, i get the same error message.
i even ungrouped it, reselected just the walls again to make sure. then tried to edit it again and got the same message
Are you using "automatic" curtain walls or "manual". (Are your spacings set in the CW definition).
How do you add a mullion? What is your process?
i do it manually, my horizontal and vertical Grid Patter is set to NONE. i was copying the gridline next to where i wanted to add a new one.
I don't know why you would want to copy a gridline - but you can. BUT - You can't copy a grid line and a mullion. If you use that process, you generate the error in question.
Curtain wall model group |
Thu, Jul 21, 2016 at 8:04:07 AM
Revit 2014 - Disappearing error message |
Wed, Nov 6, 2013 at 4:12:48 PM
ERROR MESSAGE: STAIRS - rises not intersecting boundries? |
Tue, Aug 19, 2008 at 9:12:33 AM
How to place Curtain/Glass Door for Curtain Wall for Revit Architecture 2012 |
Thu, Jul 7, 2011 at 4:27:10 PM
Revit Project to Families |
Thu, Jun 7, 2012 at 7:44:10 AM
